Grafana error message after upgrade
After upgrade I am seeing these messages every minute.
logger=search-manifest-watcher t=2026-10-29T16:09:47.668524824-04:00 level=warn msg=“manifest watcher: source listed zero manifests” source=discovery
logger=search-manifest-watcher t=2026-10-29T16:09:47.668622861-04:00 level=warn msg=“manifest watcher poll cycle: zero manifests, keeping previous set”
OS: Debian Trixie 13
Grafana:
Looking for a method to manage these.
Hi @scootertramp,
These are level=warn messages, not errors. The second one says keeping previous set, so the watcher keeps its previous state when it finds no manifests. I couldn’t find documentation for this logger, but if search and dashboards work normally, it’s most likely harmless noise.
To stop them filling your logs, silence only that logger in /etc/grafana/grafana.ini. Make sure the line doesn’t start with ;, which comments it out:
[log]
filters = search-manifest-watcher:error
If you already have a filters line, add this one after it, separated by a comma (for example filters = sqlstore:debug,search-manifest-watcher:error).
Then restart Grafana:
sudo systemctl restart grafana-server
Other logs are unaffected, and any real errors from this logger will still show.
This isn’t just noise, it is screaming from the rafters for something that doesn’t exist.
I will try your recommendation but don’t have much hope. Last time I had a similar issue adding log filters did nothing.
https://community.grafana.com/t/grafana-logging-entry-when-using-influxdb-as-a-datadource/163411
For now I will just filter it from syslog by adding to my Grafana filter.
pi@raspberry05:~ $ sudo cat /etc/rsyslog.d/10-grafana-filter.conf
# Drop if the log contains the target loggers AND the specific level key is debug
if ($msg contains '"logger":"tsdb.influx_flux"' or $msg contains '"logger":"tsdb.influxdb"' or $msg contains '"logger":"tsdb.tempo"') and ($msg contains '"@level":"debug"') then {
    stop
# Drop specific search-manifest-watcher warning messages
if $msg contains 'logger=search-manifest-watcher' and $msg contains 'level=warn' and ($msg contains 'zero manifests') then {
    stop
Here are two more error messages on this version of Grafana that I am seeing from just looking at a dashboard.
logger=context userId=1 orgId=1 uname=admin t=2026-11-01T05:42:49.509162479-05:00 level=error msg=“Request Completed” method=GET path=/apis/quotas.grafana.app/v0alpha1/namespaces/default/usage status=501 remote_addr=10.215.101.87 time_ms=3 duration=3.505511ms size=110 referer=https://raspberry05.dbonenet.com:3443/dashboards handler=/apis/* status_source=server
logger=context userId=1 orgId=1 uname=admin t=2026-11-01T05:42:49.510891373-05:00 level=error msg=“Request Completed” method=GET path=/apis/quotas.grafana.app/v0alpha1/namespaces/default/usage status=501 remote_addr=10.215.101.87 time_ms=3 duration=3.773715ms size=110 referer=https://raspberry05.dbonenet.com:3443/dashboards handler=/apis/* status_source=server
Seems like a bug from some un-used/un-configured feature.
Upgraded to latest Grafana.
Still no change with these four new messages introduced in 13.3.0.
