What Grafana version and what operating system are you using? v10.3.1
What are you trying to achieve? Display an appropriate image based on light or dark theme mode.
How are you trying to achieve it? Looking for a variable that denotes the current theme (light or dark).
What happened? Variable name doesn’t seem to exist.
What did you expect to happen? That there would be a global variable for theme or theme-name.
Can you copy/paste the configuration(s) that you are having problems with? N/A
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. NO
Did you follow any online instructions? If so, what is the URL? NO. Can’t find any instructions or documentation on internal variables for “theme” or “theme name”.
