Grafana drilldown feature of every node
    v8.5.4
    drill down each node in the dashboard to show additional details(metadata) about it
    suppose i show 5 top consuming AWS RDS instance in a dashboard. Then I want to hover my mouse on top of each of those instances, then I want to show additional details about those like instance type, db engine type details, endpoint etc based on additional processing(whatever way it can be- I am flexible)
  • What happened?
    Currently there is no feature i found about it
Is there a way to achieve this? If someone has worked on it before and can help will be great.
