Grafana DNS entry
I’ve added a DNS entry grafana-webfile.test.ag → IP of server.
I’ve also changed some line in the grafana.ini config file. Unfortunetely I cannot reach the site via grafana-webfile.test.ag. Did I miss something? Currentyl Grafana is only reachable via the IP/3000
Hi @tim197
Can you describe your setup/infrastructure a bit more? Where are you hosting your grafana instance? Are you using a reverse proxy like nginx to proxy to your domain?
