Grafana 8.2
Ubuntu 20.04 -
Display the dashboard in a continuous presentation. The dashboard displays properly in the edge browser and that is the browser used by grafana as well. -
Using the WebLive plugin for powerpoint -
What happened?
To see the dashboard displayed -
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No errors in the logs.
Grafana
If you’re seeing this Grafana has failed to load its application files
This could be caused by your reverse proxy settings.
If you host grafana under subpath make sure your grafana.ini root_url setting includes subpath. If not using a reverse proxy make sure to set serve_from_sub_path to true.
If you have a local dev build make sure you build frontend using: yarn start, yarn start:hot, or yarn build
Sometimes restarting grafana-server can help
Check if you are using a non-supported browser. For more information, refer to the list of supported browsers.
- Did you follow any online instructions? If so, what is the URL? Several from Microsoft. The WebLive plugin has a wizard it uses to configure the slide.
