Hi everyone, I’m using Grafana v5.2.0
on my localhost, I’m using postgres database.
When I’m trying to generate chart panel using direct rendering API, it is very slow. I have about 10
chart panels and 7
variables in this dashboard.
I want to know that: When I render a panel using panelId
param, and provide all other variables, does Grafana query data for all panels inside this dashboard, then select the chosen panel to render, or just query & render the one that specified by panelId
How can I speed up the rendering process? Does split the dashboard to multiple dashboard works?
Thank you!
