Grafana dashboard that displays detailed information about GitHub workflows
I am using Grafana managed by AWS with version 9.4
I am trying to create a dashboard for GitHub Actions workflows where I want to display the details of all GitHub Actions workflows along with repository details. I am looking for an automated solution for this dashboard.
I have created a GitHub data source and am trying to fetch data using workflow_usage and workflows queries.
  • What happened?
Not getting exact workflow details
I expect the dashboard to properly display GitHub workflow details, including which workflow belongs to which repository.
No
No
I’m looking for the same thing, did you manage to reach any information regarding this topic?
welcome @daliaanwar
github worksflows has rest api
and using infinity rest api datasource you can get this.
This is a fake mock rest api response from above rest api github website
or workflow usage
What specifically are you trying to visualize
Thanks for you comment and direction to Infinity datasource.
I’m facing the same challenge, I’m trying to visualize the success rate of Github Actions jobs
Please share the endpoint if there is one and what the json reply looks like and which part of the data returned you want to visualize in what kind of visualization
