ubuntu -
i want o monitor my target using promethus and grafana -
What happened?
cpu metric not show in my grafana dashboard i got this error
Status: 500. Message: bad_data: 1:112: parse error: bad duration syntax: “10m1” -
i expect that cpu metric show in grafana dashboard -
Welcome
Can you please post prometheus config obfuscated
