Grafana can't connect to Azure Monitor - Bad Gateway
Having trouble connecting the Azure Monitor data source to grafana. I am getting a 502 bad gateway. I am guessing this has to do with our infrastructure being on private network sitting behind an azure firewall. Some proxy issue. However, I can’t seem to find any documentation on how to get past the issue.
I am on our jumpbox server: Windows Server 2016
I can successfully connect to the grafana server via SSH and through the browser at http://ip:3000.
I can login to the grafana server successfully.
However, trying to add the Azure Monitor data source is not successful.
The grafana server is a debain 10.7
Please check the following, seems related to your concern :
Good Luck
Hi - I think it is related. However, I don’t see what files need to have those variables added for a debian server. The folders/files are not consistent across operating systems.
I found this for Centos :
This is the correct solution on Centos 7:
Add to file: /etc/sysconfig/grafana-server
http_proxy=http://proxy.domain:3128/
https_proxy=http://proxy.domain:3128/
no_proxy=internal.domain,127.0.0.1
Reference: Grafana 2.0b https_proxy environment configuration · Issue #1691 · grafana/grafana · GitHub
Good Luck
There is no /etc/sysconfig in a debian server. I see a grafana.ini under /opt/bitnami/grafana/conf however, I am not sure this is the area to add the http_proxy variables.
When I add the variables I still get a bad gateway
You should replace proxy.domain by your proxy
what version of grafana are you using?
Grafana 7.3.7-0 (Debian 10)
can you upgrade
  1. List item
I believe 7.3 is the latest for Grafana?
[ 7.3.7](
  1. List item
