Grafana Azure Monitor alert provisioning default datasource issues
    • 13.2.3
    • use alerts file provisioning via k8s sidecar container
    • the provisioning is fine, all that works - the azure monitor datasource is the issue
  • What happened?
    • Azure Monitor datasource has a “default subscription” so when we provision alerts with separate subscription ids within the alert config file, the datasource configuration overrides the alert configurations, so any alerts provisioned fail due to query errors (unless the alerts use the datasource default subscription). This means we would have to have a separate datasource for every subscription…
    • I expected the Alerts Query Model data to be used over the datasource defaults for the query.
    from the Alerts file config
    •         datasourceUid: myid0ez
              model:
                azureMonitor:
                  aggregation: Maximum
                  metricName: "Available Memory Percentage"
                  metricNamespace: microsoft.compute/virtualmachines
                  region: "eastus"
                  resources:
                    - resourceGroup: "myrg"
                      resourceName: "myrsname"
                      subscription: "07eb7777-ce00d-77a7-7b77-bc77c77fd7e0"
    • the datasource JSON from the database that fails with query errors for all alerts file provisioned.
      {“azureCredentials”:{“authType”:“clientsecret”,“azureCloud”:“AzureCloud”,“clientId”:“some-client-id”,“tenantId”:“some-tenant-id”},“pdcInjected”:false}
    • [sse.dataQueryError] failed to execute query [A]: request failed, status: 400 Bad Request, body: {“error”:{“code”:“InvalidSubscriptionId”,“message”:“The provided subscription identifier ‘resourceGroups’ is malformed or invalid.”
    • The Azure Monitor datasource was configured without a default subscription (intentionally). The provisioned alerts should use the defined subscription, not the subscription within the datasource (and when none is configured, the query call ends up malformed).
okay.. seriously - shortly after posting this I figured out the issue.. we were missing the subscription value for the model as well, you have to include the subscription value in the model and the resources definitions. :slight_smile: Otherwise it defaults to the datasource default, and if there is none, it errors…
