Grafana Assistant and Elicitation
We’re using a custom MCP Server that provides support for elicitation for many “write” operations e.g. “Are you sure you want to do this?”. Does the Grafana Assistant support elicitation in MCP servers? We’ve tested this and it does not work currently.
I would no, because there is no match for that the doc.
If you have support, then ask support for that feature.
