Hi all,
we are using grafana 5.3.2 docker image with sqlite persistence.
Due a question about the magellan remote code execution vulnerabiliy in sqlite I have to check which version of sqlite is grafana working on and if it’s using sqlite’s FTS3 feature.
I was not able to found these information: could you please address or tell me this informations?
I can see from go source that there is a go sqlite3 driver but I’m not able to found the related sqlite version.
–EDIT more precise data:
Affected sqlite versions are < 3.25.3 with FTSE extension enabled.
Thank you in advance.
Rob
