Hey,
I’m getting strange images for alerts on my email channel since 5.3.0 in which the graph doesn’t get rendered correctly.
any ideas?
Thanks,
Eugene.
Too wide legend? Try to disable legend or configure position of the legend below graph.
Hey!
Thanks for the quick response!
The legend is not wide as you see the series names I covered by the white rectangle are the max length.
Same issue happens when I try to share a direct image of the graph.
When the legend is below or disabled it seems that the image is rendered correctly, or at least I could see the graph.
This issue is new to 5.3.0 since I’ve used those alerts since 5.2 beta when ES alerts was introduced.
@torkel - do you have any ideas on whats going on here? started with the latest version
