Grafana OSS v10 and hosted in Azure AKS
Grafana agent v0.34 installed in RedHat 8 servers -
Grafana agent usage-reporting currently sending to https://stats.grafana.org/agent-usage-report
And would like to send to AKS grafana -
What happened?
Grafana agent usage-reporting currently sending to https://stats.grafana.org/agent-usage-report -
Grafama agent usage-reporting send to https://stats.grafana.org/agent-usage-report -
Server did not fully allow accessing to internet. Hence, client timeout is expected
grafana-agent[1969898]: ts=2023-06-18T07:21:19.130326648Z caller=reporter.go:129 level=info msg=“failed to report usage” err=“5 errors: Post "https://stats.grafana.org/agent-usage-report\”: context deadline exceeded (Client.Timeout exceeded while awaiting headers); Post "https://stats.grafana.org/agent-usage-report\“: EOF; Post "https://stats.grafana.org/agent-usage-report\”: context deadline exceeded (Client.Timeout exceeded while awaiting headers); Post "https://stats.grafana.org/agent-usage-report\“: EOF; Post "https://stats.grafana.org/agent-usage-report\”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
- Did you follow any online instructions? If so, what is the URL?
Cannot find any related instructions
Here is my current grafana-agent configuration
integrations:
node_exporter:
enabled: true
# disable unused collectors
disable_collectors:
- ipvs #high cardinality on kubelet
- btrfs
- infiniband
- xfs
- zfs
# exclude dynamic interfaces
netclass_ignored_devices: "^(veth.*|cali.*|[a-f0-9]{15})$"
netdev_device_exclude: "^(veth.*|cali.*|[a-f0-9]{15})$"
# disable tmpfs
filesystem_fs_types_exclude: "^(autofs|binfmt_misc|bpf|cgroup2?|configfs|debugfs|devpts|devtmpfs|tmpfs|fusectl|hugetlbfs|iso9660|mqueue|nsfs|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|selinuxfs|squashfs|sysfs|tracefs)$"
# drop extensive scrape statistics
metric_relabel_configs:
- action: drop
regex: node_scrape_collector_.+
source_labels: [__name__]
relabel_configs:
- replacement: testvm01.com
target_label: instance
prometheus_remote_write:
- basic_auth:
password: admin
username: admin
url: http://prometheus.com:9090/api/v1/write
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
- action: keep
regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:
- __name__
logs:
configs:
- clients:
- url: http://loki.com:3100/loki/api/v1/push
positions:
filename: /tmp/positions.yaml
scrape_configs:
- job_name: integrations/node_exporter_journal_scrape
journal:
max_age: 24h
labels:
instance: testvm01.com
job: integrations/node_exporter
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- source_labels: ['__journal__boot_id']
target_label: 'boot_id'
- source_labels: ['__journal__transport']
target_label: 'transport'
- source_labels: ['__journal_priority_keyword']
target_label: 'level'
- job_name: integrations/node_exporter_direct_scrape
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/{syslog,messages}
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
password: 1234abc455
username: admin
scrape_configs:
global:
scrape_interval: 60s
Blockquote
