Grafana-agent (linux) won't run as grafana-agent after being run as root [SOLVED]
    grafana-agent 2024-01-19T11:55:16Z
    Run as user grafana-agent from system.d
    in /lib/systemd/system/grafana-agent.service:
User=grafana-agent
  • What happened?
For debugging purposes I executed the grafana-agent go script as root user. Following that, the systemd script now fails when setting the daemonisation user to the inbuilt ‘grafana-agent’ user. When the User= line is commented out and grafana-agent is run as root, it executes fine.
This is not optimal from a security perspective.
I assume that there may be some file permission somewhere that is being set which results in the script not executing, but I can’t find it.
grafana-agent runs as a daemon under the grafana-agent user.
grafana-agent.service: Start request repeated too quickly.
As always, found it just after asking for help.
The file /tmp/positions.yaml is created with the permissions of the running user and needs to be manually deleted, or a ‘permission denied’ error is generated.
