8.5.13 + -
Display custom panel legend in a container element -
Using flot -
What happened?
react-dom.production.min.js:216 TypeError: e.find(…).html is not a function
** at jquery.flot.js:2818:42**
** at N (jquery.flot.js:1674:7)**
** at new a (jquery.flot.js:716:5)**
** at e.plot (jquery.flot.js:3296:16)** -
No error, panel with legend displays correctly -
at e.plot (jquery.flot.js:3296:16) -
Flot Examples: Graph Legend
I just made it work by setting the legend after calling $.plot(ref.current, plotData, plotConfig)
But it seems that the flot version in grafana 9 at least is not the latest, and trying to use the container property in the configuration will have this issue.
