# Grafana 7 and Zabbix Plugin
**URL:** <https://community.grafana.com/t/grafana-7-and-zabbix-plugin/31459>\
**Category:** Grafana\
**Created:** [June 4, 2020, 9:18am UTC](https://community.grafana.com/t/grafana-7-and-zabbix-plugin/31459 "2020-06-04T09:18:35Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![davdhillon](https://avatars.discourse-cdn.com/v4/letter/d/a8b319/32.png) [@davdhillon](https://community.grafana.com/u/davdhillon)\
**Post date:** [June 4, 2020, 9:18am UTC](https://community.grafana.com/t/grafana-7-and-zabbix-plugin/31459/1 "2020-06-04T09:18:35Z")
</div>
Last week I upgraded Grafana from 6.6.7 to 7.0.1.
Since the upgrade the Zabbix plugin has not been working properly. The plugin was also upgraded to the latest version.
Since the upgrade I have seen a few issues;
- Dashboards generally slow to load.
- Dashboards using variables take an age to update.
- The Zabbix Problems graph doesn’t seem to be updating with recent data.
- Timeout warnings have been displayed on panels using Zabbix datasources.
The Zabbix environment has remained the same, its version 4.4.8
I’m hoping there is a solution, otherwise I will have to roll back to the older version as version 7 is not reliable.
Thanks.
