Trying to learn grefana by setting up simple basic 101 installed ORACLE DB (I AM A DBA) and also installed GREFANA on laptop and also setup grefana cloud but then stuck. not sure what to do to make grefana connect to my oracle db. I AM A BIT LOST, not sure what is OSS and cloud, and what to do next? I can pay for support if needed, need to learn
GRAFANA FORUM’S 3 BEST PRACTICES:
- Please post insiSde a subcategory
- For questions and advice, please try to use the template below
- If you post a question and someone solves it, please mark is as SOLVED
~ THANK YOU!! the grafana team
What Grafana version and what operating system are you using? enterprise but i can use any version just need to know which version to use, os windows
What are you trying to achieve? BASIC 101 HELLO WORLD
How are you trying to achieve it? FOLLOWED DOCUMENTS OR ONLINE STEPS
What happened? NOT SURE – CONNOT CONNECT FROM GREFANA CLOUD TO MY LAPTOP TIME OUT ERROR
What did you expect to happen? WORK - CONNECT TO MY LAPTOP ORACLE DB
Can you copy/paste the configuration(s) that you are having problems with? HOW DO I COLLECT THE CONFIG DATA?
