Graf Problem with Courency
Hello
I have a problem with this Graf.
first there should be a space between the CHF and the number!
second the price on the right side is wrong it should also show the cents and not Swiss Franks.
have a nice day
vinc
Did you use the currency field on the panel setup or is It coming from your datasource as it is.
If you are using the currency field and suspect there is a typo with the display, I suggest you open an issues on the GitHub repo.
Good Luck
@wlargou thanks for your feedback
the CHF probelem i just overwrite it and works but still why it is showing on the right Y side
like 8.22 and not 0.82 like it is!
the Bottem of the Graf show also the correct value!
have a nice day
vinc
