Hi all. I am very new to Grafana but have been able to install it over a new Zabbix server install. I am new to Zabbix as well but I am having some successes with it. I have successfully configured Zabbix to poll a couple of our microwave radios via SNMPv3 and pull back several key performance statistics that need to be actively monitored. Once that was done and getting data, I jumped right in and installed Grafana and its Zabbix plugin. Within a couple of days, I was able to build a pretty good dashboard from the Zabbix data.
Now I would like to be able to use the globalnoc-networkmap-panel to build a realtime network map of the entire microwave path to provide an overview of the system.
I can find it at GitHub but it does not include any installation notes so I am unsure of how to install the plugin manually. The README.md.does not include any installation instructions.
Do any of you know where I can find the installation instructions or point me to where I can find instructions to install it manually? Thanks in advance.
I had a sneaking suspicion that was what was needed but being new to the platform, I thought it would be wise to ask first.
BTW - I am very impressed with the platform’s robustness. While I am just a network person and I mostly just want to have a clear and concise picture of my network and its components, I can see its use in other areas and tied to other input sources.
The README file does not tell you. But, you need to read the BUILD file for the installation instructions. I had to install node.js first before I could perform the commands in the BUILD file.
Sent from my KYOCERA DuraForce PRO, an AT&T 4G LTE smartphone
I am working on the integration of Zabbix and globalnoc-networkmap-panel on Grafana currently. I installed the globalnoc-networkmap-panel in the Grafana, but the map cannot show successfully. Could you please give some instructions about how to show the map and import related data from Zabbix?
