# Getting Unknown module: k6/x/kafka with kafka extensions
**URL:** <https://community.grafana.com/t/getting-unknown-module-k6-x-kafka-with-kafka-extensions/98743>\
**Category:** OSS Support\
**Created:** [May 16, 2021, 12:27pm UTC](https://community.grafana.com/t/getting-unknown-module-k6-x-kafka-with-kafka-extensions/98743 "2021-05-16T12:27:12Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![yorkmena](https://avatars.discourse-cdn.com/v4/letter/y/eb9ed0/32.png) [@yorkmena](https://community.grafana.com/u/yorkmena)\
**Post date:** [May 16, 2021, 12:27pm UTC](https://community.grafana.com/t/getting-unknown-module-k6-x-kafka-with-kafka-extensions/98743/1 "2021-05-16T12:27:12Z")
</div>
Getting below error while running the k6 script mentioned in the Readme on below kafka extension using this command:
> **[GitHub - mostafa/xk6-kafka: k6 extension to load test Apache Kafka with...](https://github.com/mostafa/xk6-kafka)**
> k6 extension to load test Apache Kafka with support for various serialization formats, SASL, TLS, compression, Schema Registry client and beyond - GitHub - mostafa/xk6-kafka: k6 extension to load t...
`./k6 run script.js`
Build k6 with xk6 using below command:
`./xk6 build --with github.com/mostafa/xk6-kafka`
**Error** :
```auto
ERRO[0001] GoError: unknown module: k6/x/kafka
	at reflect.methodValueCall (native)
	at file:///home/ashish_22484/xk6_compiled/rtddkafka.js:55:47(22) hint="script exception"
**OS** : Amazon linux2
**go version** : go1.15.8 linux/amd64
& same on
**OS** : OSx Bigsur
**go version** :go1.14.15 darwin/amd64
**Author:** ![mstoykov](https://sea2.discourse-cdn.com/grafana/user_avatar/community.grafana.com/mstoykov/32/35309_2.png) [@mstoykov](https://community.grafana.com/u/mstoykov)\
**Post date:** [May 16, 2021, 1:08pm UTC](https://community.grafana.com/t/getting-unknown-module-k6-x-kafka-with-kafka-extensions/98743/2 "2021-05-16T13:08:03Z")
</div>
Hi @yorkmena,
I answered you in the [github issue](https://github.com/mostafa/xk6-kafka/issues/7), but tldr: you can run `xk6 build --with github.com/mostafa/xk6-kafka@bb0ceb8` and it will produce binary that will work for you.
**Post date:** [May 16, 2021, 4:38pm UTC](https://community.grafana.com/t/getting-unknown-module-k6-x-kafka-with-kafka-extensions/98743/3 "2021-05-16T16:38:48Z")
</div>
Yes it worked. Thanks:)
