Getting null websocket error in browser console
    Grafana version = 8.3.4
Trying to load grafana in iframe with auth proxy
  1. I have enabled the auth proxy in grafana conf
  2. I have a proxy that authenticates a user and forwards the request
  3. I am using axios get in which I pass my auth headers, I receive a response as an HTML which i try to load in my iframe using srcDoc
  4. js and CSS loads which I can see in my network log
I get following error in the browser console
angular.js:15697 DOMException: Failed to construct ‘WebSocket’: The URL ‘null/grafana/api/live/ws’ is invalid.
at f.value (http://localhost:8080/grafana/public/build/5105.1322a38d8e955d3d27e7.js:2:1977487)
    it should have my host name in place of null
#################################### Server ##############################
protocol = http
http_port = 3002
domain = localhost
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana
serve_from_sub_path = true
[auth.proxy]
enabled = true
header_name = X-WEBAUTH-USER
header_property = username
auto_sign_up = true
Deprecated, use sync_ttl instead
ldap_sync_ttl = 60
sync_ttl = 60
whitelist =
headers =
enable_login_token = true
