Getting error 'Unknown Field Options' when doing browser testing
Hi, I am following a sample script for browser testing using k6.
import { browser } from 'k6/experimental/browser';
import { check } from 'k6'
export const options = {
  scenarios: {
    ui: {
      executor: 'shared-iterations',
      options: {
        browser: {
          type: 'chromium',
export default async function () {
  const page = browser.newPage();
  try {
    await page.goto('https://test.k6.io/my_messages.php');
    page.locator('input[name="login"]').type('admin');
    page.locator('input[name="password"]').type('123');
    const submitButton = page.locator('input[type="submit"]');
    await Promise.all([
      page.waitForNavigation(),
      submitButton.click(),
    check(page, {
      'header': page.locator('h2').textContent() == 'Welcome, admin!',
  } finally {
    page.close();
I am using version 0.46. When i run the script, I am getting issue:-
ERRO[0000] could not initialize ‘tests/testk6.js’: could not load JS test ‘file:///C:/Users//.js’: json: unknown field “options”. Any idea about that?
Hi @neha29,
Welcome to the community forum :wave:
The good news is that the script works well on my laptop with v0.46.0. Though I use a Mac and you seem to be on Windows. Is that correct? It could either be a platform/installation issue, or how you run the command.
Can you tell us how you installed and run k6? Are you using the k6 binary or a Docker image? If you can also share the command you run and some more context, we might be able to help you.
Cheers!
I am experiencing the same behaviour using v0.48.0 installed via the Windows MSI file from. I use the k6 binary to run the test and Babel and Webpack to transpile TypeScript files into JavaScript.
Script:
import { browser } from ‘k6/experimental/browser’;
// load test config, used to populate exported options object:
const testConfig = JSON.parse(open(‘./options.json’));
export const options = testConfig;
const browser = new Browser();
try {
    await page.goto('https://test.k6.io/');
    page.screenshot({ path: 'screenshot.png' });
} finally {
    page.close();
options.json:
“scenarios”: {
“ui”: {
“executor”: “shared-iterations”,
“options”: {
“browser”: {
“type”: “chromium”
webpack
k6 run dist/poc-test.js
Thanks for any guidance!
Hi @thebigdombowsky welcome to the community forum!
For me this two files works with k6 v0.48.0 with the k6 run script.js command.
script.js:
const testConfig = JSON.parse(open('./options.json'));
  try {
  } finally {
    page.close();
options.json:
  "scenarios": {
    "ui": {
      "executor": "shared-iterations",
      "options": {
        "browser": {
          "type": "chromium"
Can you confirm, that this works for you, or still fails?
Hi @bandorko,
Thanks for the quick reply!
Unfortunately, I still receive the error
“ERRO[0000] could not initialize ‘script.js’: could not load JS test ‘file:///C:/Development/performance/k6-multiprotocol/src/script.js’: json: unknown field “options””.
I wasn’t receiving the error before I upgraded to v0.48.0 using the test below
const options = {
scenarios: {
pickNewOrders: {
executor: ‘constant-vus’,
options: {
vus: 1,
duration: ‘10s’,
browser: {
type: ‘chromium’,
export async function pickNewOrders() {
const user = Selector(‘#username’)
const password = Selector(‘#password’)
const login = Selector(‘#kc-login’)
const pickMenu = Selector(‘#medportal_pick > span.p-menuitem-text’)
const pickNewOrders = Selector(‘#medportal_new_order > span’)
try {
    await page.goto('https://example.com/'),
        await Promise.all([
            user.fill('systemadmin'),
            password.fill('max'),
            login.click(),
    await Promise.all([
        pickMenu.isVisible(),
        pickMenu.click(),
    await Promise.all([
        pickNewOrders.isVisible(),
        pickNewOrders.click(),
        await page.waitForLoadState({ waitUntil: 'networkidle2' }),
} catch (error) {
    console.log(error)
} finally {
    await browser.close()
@thebigdombowsky :
For me there are a couple of issues with this script also, but first of all, you have to export your const options
@bandorko Please disregard the second script, as I pasted it in error. Below is what I am running and receiving the error from.
script.js
import { Browser } from 'k6/experimental/browser';
    try {
    } finally {
        page.close();
options.json
    "scenarios": {
    "ui": {
        "options": {
        "browser": {
            "type": "chromium"
Output
ERRO[0000] could not initialize 'script.js': could not load JS test 'file:///C:/Development/performance/k6-multiprotocol/src/script.js': json: unknown field "options"
@thebigdombowsky :
I can’t reproduce your problem. Can you give me more information?
  • what is the exact command you are running?
  • what is the output of the k6 version command?
Hi @bandorko
Apparently, k6 0.43.1 was installed using Chocolatey, and I updated it to 0.48.0 using the MSI. I just updated the k6 package using choco install k6 --version 0.48.0, and the script executes perfectly. Thanks for your help!
