Get User Feedback from Alerts?
Hi!
Is it possible to capture user feedback using the Alert Engine? For example, if I have Grafana alert the user because a certain anomaly has occurred within a time series, is it possible to get a simple ‘Yes/No’ from the user to see if the anomaly truly is an anomaly? This will enable supervised-learning when enough time series are labelled by the user.
If this is NOT possible has anyone figured out any sort of workaround? I am sure I am not the first person to think of this.
Thanks :slight_smile:
Mikey
