Hello. If I select previous week in grafana it works perfect but if I do it in that way from the Render API like that:
http://IP:PORT
/render/?target=alias(summarize(sumSeries(My_data),‘1h’,‘sum’,false),‘INGRESS_IN’)
&midnight+monday-1w&until=midnight+monday&format=csv
I get something like this:
First hour is 01:00 of day 1 of 7
Last hours are 00:00 and 01:00 of day 8 (?¿) . And data for 01:00 is not correct (lower value)
Which would be the correct format to get the right date from the API? (Grafana is set on local time)
Thanks in advance
