Geomap: real-time marker size works only when size field is in same data frame?
I want marker sizes in Geomap to change dynamically in real time based on a numeric value.
It seems that:
  • Size changes work only when the size field is in the same data frame as latitude/longitude
  • If the size value comes from another datasource or another query, the marker size is ignored
Is this:
  • An expected limitation of Geomap?
  • The recommended design pattern?
  • Or is there a way to reference size fields across data sources?
Thanks!
style.dims = getStyleDimension(frame, style, theme);
style dimensions are calculated using the only frame that you select in Data field (query).
So I can’t use a value that is the result of transformation ??
the result of transformation is a frame that you then select as a Data source for the layer. So why not?
The problem is my dataframe is also a transformation , so I get errors when I do more transformations :frowning:
