GCP Monitoring API Requests
Hi All ,
I am currently using Grafana to collect GCP monitoring data.
It is estimated that there are the following 5 types of GCP data collection (CPU usage, memory usage, NetworkIn, NetworkOut, disk usage)
If I want to call the indicators listed above, do I need to call the API 5 times?
Or do I only need to call the API once to get all the metrics?
Many Thanks!
Hi All ,
Maybe someone can answer your question as it stands, but I don’t understand
some of the terms you’ve used, so maybe a bit of clarification would help
others too?
Firstly, what is GCP?
Okay, understood.
times?
Which API are you referring to?
Antony.
I want to use Grafana to collect GCP monitoring (Google Cloud Platform Stackdriver Monitoring) data.
Because ELK has been used to collect data on AWS before, he can collect all the data of the VM at once.
So I want to know if it is possible to get GCP monitoring data on Grafana (collect all data at once)?
Or do you need to perform 5 requests to collect the above metrics?
Many Thanks
