Hi. It is possible to combine gannt vars like var(open,close) in standart graph please ?
Thanks.
What do you envision your graph to look like? Would it be like a standard Gantt chart?
Example:
I would display in graph some Bool/ 2state vars as gannts boiler ON/OFF, warming enabled etc.
and some vars like temperatures etc. standart as “curved” lines on y axis an time on x axis.
This means on query level should be possible to define a variable as gannt line and other as standard time queries.
AFAIK, that will require multiple panels (each with it’s own query, like this):
The bottom two are State timelines.
YES thanks, but it will be nice to have gannt and standard in one graph or ?
It belongs together, if you scroll with ruler.
Maybe a wish in next versions of beautiful grafana.
I used this combination often in professional Scada system like zenon from Copadata.
You do not need to install that plugin. Use the State timeline graph.
There is no option to hide the x-axis as far as I am aware of.
