What Grafana version and what operating system are you using? Linux vmubuntu01 6.17.0-41-generic
What are you trying to achieve? I’m trying to create a web styled interface, three panels, one a navbar, one a footer and a main panel.
How are you trying to achieve it? Display data in the main panel about data center devices in a rack layout
What happened? I have this working in a test system at work. I’m using 11.6 Grafana and Busines-Test visualization so I can use HTML, CSS and JScript. In work this is all working fine. However at home, I cannot get this to work. I have tried version 13. tried using different plugins, removed Grafana and re installed. I’ve tried pretty much everything to get this to work and it keep failing. I have the navbar and footer working but the main panel is now throwing an error. I can add my SQL to the code and run query to return data but as soon as it tries to render in the main panel, it throws error. It also references dynamictext in the error message, which is not selected. I’m thinking there is some quirk or maybe an olde file or even permissions to a folder that is not allowing me to use business text and defaults to dynamictest. I did have a problem accessing plugins at one point and had to change permissions. I wonder if perhaps Grafana cannot access certain key folders. The error is as below "ReferenceError: data is not defined
at Fl (http://192.168.1.14:3000/public/plugins/marcusolsson-dynamictext-panel/module.js?_cache=6.2.0:363:2834)
at jl (http://192.168.1.14:3000/public/plugins/marcusolsson-dynamictext-panel/module.js?_cache=6.2.0:421:1210)
at div
at div
at http://192.168.1.14:3000/public/plugins/marcusolsson-dynamictext-panel/module.js?_cache=6.2.0:426:640
at o (http://192.168.1.14:3000/public/build/8501.a435c109505704b50aad.js:1:513)
at y (http://192.168.1.14:3000/public/build/8501.a435c109505704b50aad.js:12:151786)
at s (http://192.168.1.14:3000/public/build/8501.a435c109505704b50aad.js:12:152332)
at div
at section
at L (http://192.168.1.14:3000/public/build/8501.a435c109505704b50aad.js:32:26870)
at div
at div
at Op (http://192.168.1.14:3000/public/build/7107.acb14953ceccac835c4c.js:17:167406)
at ee (http://192.168.1.14:3000/public/build/7107.acb14953ceccac835c4c.js:15:100700)"
What did you expect to happen? In test it works fine, no issues, I get a grid layout of tables representing racks in a datacenter with devices and hostnames displayed.
I’ve install the Business Text plugin from the plugins menu but I’m wondering if I need to install this independently so that it goes into the correct folder for 11.6. I’ve gone around in circles for several days, tried as much as I can to get it working. I think this will be a simple fix but I have yet to find it. Any help of advise is much appreciated
Likely cause → your JavaScript may still be using the old data parameter. Business Text 5.0 changed the code API so data is accessed through context.data.
If your code contains a bare data reference, try →
const data = context.data;
Then you can continue using data in the rest of your code.
Also check the panel’s Render template setting (Every Row, All Rows, or All data), since this determines what context.data contains.
your log shows →
POST /api/ds/query status=401
error="token needs to be rotated"
Log out and back in, then check whether those 401 errors continue. If they do, resolve that authentication/session issue as well, because the datasource query itself is being rejected.
I would not change plugin-folder permissions or manually reinstall the plugin yet.
Finally, if the home system is running Grafana 13 with Business Text 6.2.0, check that combination first. Business Text 6.x is documented as supporting Grafana 11 and 12, not Grafana 13
Hi thanks for getting back to me. I am getting data back for a few seconds. But its just the JSON data as shown below.. It shows in refresh, then a few seconds later I get the error
Your main.js confirms it → this needs a render mode + data access change.
Your script loops over every asset at once
(for (let i = 0; i < ASSETID.length; i++))
to group devices into racks it needs the entire result set in a single execution.
That can’t work in Every Row mode, where Business Text calls your function once per row. And per the plugin source checked directly against VolkovLabs/business-text on GitHub, context.data.series doesn’t exist in any render mode → this isn’t a naming fix, the data-access approach needs to change.
1. Change Render template: Every Row → All Rows (not All data → that’s for multiple queries/frames; you only have one).
2. Rewrite the data extraction. In All Rows mode, context.data is an array of row objects, one per DB row, keyed by your SQL column names. Drop the fields[n].values indexing:
js
const container = document.getElementById('rack-container');
if (!context.data || context.data.length === 0) {
container.innerHTML = "No data returned from MySQL.";
return;
function getRackKey(row) {
return `${row.building}-${row.room}-${row.row}-${row.rack_position}`;
const racks = {};
context.data.forEach(row => {
const key = getRackKey(row);
if (!racks[key]) racks[key] = [];
racks[key].push({
hostname: row.fqdn.split('.')[0],
ustart: parseInt(row.ustart),
uend: parseInt(row.uend),
machinetype: row.machinetype,
description: row.description,
serial: row.serial,
ip: row.ip,
owner: row.owner,
custodian: row.custodian,
parent: row.parent,
cpu: row.cpu_usage,
mem: row.mem_usage
// rest of your rack/HTML-building loop stays the same
Everything from // Build HTML for racks onward is unaffected → only the extraction block changes.
Still worth confirming separately → whether the session.token.rotate 401s stop after a re-login, and whether disable_sanitize_html = true is set under [panels].
Thanks for the code update. I have implemented, set disable_sanitize = true and added the code snipet. Still seeing error 0 An unexpected error happened
TypeError: Cannot set properties of null (setting 'innerHTML') at Fl (http://192.168.1.14:3000/public/plugins/marcusolsson-dynamictext-panel/module.js?\_cache=6.2.0:363:2834) at jl (http://192.168.1.14:3000/public/plugins/marcusolsson-dynamictext-panel/module.js?\_cache=6.2.0:421:1210)
I think I have some sort of mismatch and for some reason I cant work out what is out. I can go one way or another but each time it gets blocked. I’m not sure why work version works and this version which I believe to be the same doesn’t The only difference is that the work systems uses API to get the data, while the home one I built a sample DB table to get the data, so two different data sources. Need to head into work now, will try again later. Regards James
