Forwarding logs to external lokistack with vector
Hello, I having been trying to setup a grafana loki stack instance on an OpenShift cluster that aggregates logs from many OpenShift cluster. I am using vector as the log forwarder on the source clusters which forwards to the lokistack on the one destination cluster, but I have been running into 302 errors when trying to forward the logs to the external lokistack route endpoint. Does anyone have any ideas on what I am doing wrong here? I am using openshift-logging tenant mode which creates application, infrastructure, and audit tenants. I tried exposing the gateway http service without tls, but I get a 400 error saying that I am sending http packets to an http server. Thank you in advance.
LokiStack:
apiVersion: loki.grafana.com/v1
kind: LokiStack
metadata:
namespace: loki-logging-grafana
spec:
hashRing:
type: memberlist
limits:
global:
  ingestion:
    ingestionBurstSize: 32
    ingestionRate: 24
    maxLineSize: 256000
    perStreamRateLimit: 5
    perStreamRateLimitBurst: 20
  queries:
    queryTimeout: 10m
  retention:
    days: 7
managementState: Managed
storage:
schemas:
  - effectiveDate: '2020-10-11'
    version: v13
secret:
  type: s3
tls:
  caName: loki-s3-ca-grafana
storageClassName: volumes-primary
tenants:
mode: openshift-logging
Vector Cluster Log Forwarder:
apiVersion: observability.openshift.io/v1
kind: ClusterLogForwarder
metadata:
namespace: loki-log-forwarder
spec:
outputs:
- loki:
    tenantKey: infrastructure
    url: 'https://logging-loki-grafana-loki-logging-grafana.apps.ocpadm.fedins.com/api/logs/v1/infrastructure'
  tls:
    ca:
      key: ca-bundle.crt
      secretName: fed-ca-bundle
  type: loki
pipelines:
- inputRefs:
    - infrastructure
  outputRefs:
    - loki-infra
serviceAccount:
Cluster Log Forwarder Pods Logs:
2025-12-05T16:07:00.711934Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::component_events_dropped: Internal log [Events dropped] is being suppressed to avoid flooding.
2025-12-05T16:07:09.704677Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector::sinks::util::retries: Internal log [Non-retriable error; dropping the request.] has been suppressed 7 times.
2025-12-05T16:07:09.704907Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector::sinks::util::retries: Non-retriable error; dropping the request. error=Server responded with an error: 302 Found internal_log_rate_limit=true
2025-12-05T16:07:09.705288Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::service: Internal log [Service call failed. No retries or retries exhausted.] has been suppressed 7 times.
2025-12-05T16:07:09.705301Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::service: Service call failed. No retries or retries exhausted. error=Some(ServerError { code: 302 }) request_id=1795 error_type=“request_failed” stage=“sending” internal_log_rate_limit=true
2025-12-05T16:07:09.705589Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::component_events_dropped: Internal log [Events dropped] has been suppressed 7 times.
2025-12-05T16:07:09.705594Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::component_events_dropped: Events dropped intentional=false count=2 reason=“Service call failed. No retries or retries exhausted.” internal_log_rate_limit=true
2025-12-05T16:07:10.734796Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector::sinks::util::retries: Internal log [Non-retriable error; dropping the request.] is being suppressed to avoid flooding.
2025-12-05T16:07:10.734924Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::service: Internal log [Service call failed. No retries or retries exhausted.] is being suppressed to avoid flooding.
2025-12-05T16:07:10.734968Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector_common::internal_event::component_events_dropped: Internal log [Events dropped] is being suppressed to avoid flooding.
2025-12-05T16:07:20.728491Z ERROR sink{component_kind=“sink” component_id=output_loki_infra component_type=loki}: vector::sinks::util::retries: Internal log [Non-retriable error; dropping the request.] has been suppressed 8 times.
