Format as table not available for other Datasources (e.g Google Cloud Monitoring)
I am using Grafana V9.0.4
I am trying to create a table for the GKE with Google Cloud Monitoring Datasource
Eventually create a table with Namespace as rows and other metrics as values.
There is no option to format as table for the Google Cloud Monitoring Datasource, I see that option only for the Prometheus Datasource.
Currently as you see in the screenshot the values are in the dropdown. Instead if we can format them to table that helps.
Looks like there is not direct support to format as table, instead can we do something with transform?
Trying to create something like this
