9.4.1 running on Rasberry PI4 Buster.
Make the line quiet.
Receiving a solution.
What happened?
The line in the to right corner is fast moving left and right. Almost impossible to point the mouse to for example on the ‘save’ button.
The reason of this flikkering is that the last button which is the “cycle view mode” is moved left to make place for 3 vertical dots.
Don’t know this question.
No
Don’t have any errors
Did you follow any online instructions? If so, what is the URL? No
