Filtering Transactions based on Application name for Jmeter scripts
I have multiple jmeter scripts(3 to 4) running at same time and i am pointing all results to same database(in influxdb) and i would like to filter my dashboard data based on tests i select from dropdown at top (tag).
Could you please help me how to do that?
if your data has a localhost as a variable you can filter by that
if not I would may be recommend using telegraf to filter your data or find a way to add a host variable attached to the perfomance data
example
date HOST perf
date host1 99%
you can select HOST as variable in the quert then use queries for other values
