Filter logs from a container using promtail
We are trying to filter logs only from one container from a multicontainer pod.
specifically, we are trying to get logs only from istio-proxy container from all the pods running in a cluster.
is it possible to to filter like that ?
yes it is possible.
Check this documentation Pipelines | Grafana Loki documentation.
You can do something simple like this:
- match:
      selector: '{logs="container_logs"} !~ ".*istio-proxy.*"'
      action: drop
This will drop all lines that don’t include “istio-proxy”.
Yes, it is possible to filter logs from a specific container within a multi-container pod in a Kubernetes cluster. You can achieve this using the kubectl logs command with the -c flag to specify the container name. In your case, to get logs only from the istio-proxy container, you would run:
phpCopy code
kubectl logs -c istio-proxy <pod-name>
This command will display logs only from the istio-proxy container within the specified pod. Keep in mind that the kubectl logs command fetches logs from a single container, so you’ll need to run it for each pod you want to inspect.
