Filter Logfiles for different ip subnets?
Hello everybody,
my task is to filter our logs against different ip subnets in form 1.1.1.0/16. (only an example).
Is there any possible way to do this via grafana and loki?
I am new to loki, so i have to learn much new things.
The only thing i have already done is to filter against one single ip.
Can anybody help me please?
Thanks in advance.
Hi @tofu1
Currently Loki doesn’t support ip matcher with subnet. It’s under implementation. More discussion here.
Hi @kavikanagaraj,
thx for the infos.
Hi @kavikanagaraj ,
i have seen the latest update.
Thats awesome. IP Matcher looks good.
Unfortunately i need a little bit help.
I want to filter for a few cidr.
I want to filter incoming traffic from different subnets over one day.
My example query:
topk(100, sum by (sourceip,destport,protoname) (count_over_time({job=~“syslog”, host=“OPNsense.localhost”,action=“block”,interface=“igb0”,direction=“in”} | sourceip = ip(“192.168.1.0/24”) , ip(“192.168.4.0/24”) , ip(“192.168.30.0/24”) , ip(“193.222.200.0/23”) [1d])))
One cidr is working fine, but not more.
This is working:
topk(100, sum by (sourceip,destport,protoname) (count_over_time({job=~“syslog”, host=“OPNsense.localhost”,action=“block”,interface=“igb0”,direction=“in”} | sourceip = ip(“193.222.200.0/23”) [1d])))
Perhabs you have an idea?
Thanks in advance.
Ok, i found an workaround for the beginning.
topk(100, sum by (sourceip,destport,protoname) (count_over_time({job=~“syslog”, host=“OPNsense.localhost”,action=“block”,interface=“igb0”,direction=“in”} | sourceip = ip(“192.168.1.0/24”) or sourceip = ip(“192.168.4.0/24”) or sourceip = ip(“192.168.30.0/24”) or sourceip = ip(“193.222.200.0/23”) [1d])))
Perhabs anyone have a better solution?
From the “Logql Matching IP” website:
A CIDR specification. Examples: ip("192.51.100.0/24") , ip("2001:db8::/32")
Hi @tofu1. Thanks for trying out IP matcher.
If you want to match multiple CIDR pattern you can always chain together as multiple label filters.
e.g:
| sourceip = ip(“192.168.1.0/24”) | sourceip=ip(“192.168.4.0/24”) | sourceip =ip(“192.168.30.0/24”) | sourceip = ip(“193.222.200.0/23”
Hope that should solve your problem!
Thanks @kavikanagaraj :slight_smile:
