Filter by name: Only show values having "percentage" in it
Hello there,
I’d like to use grafana to filter values by name:
This is an example of my keys and values:
disk_usage.root.dev.used 0 1608582030
disk_usage.root.dev.avail 7816 1608582030
disk_usage.root.dev.used_percentage 0 1608582030
disk_usage.root.run.used 147 1608582030
disk_usage.root.run.avail 1420 1608582030
disk_usage.root.run.used_percentage 10 1608582030
disk_usage.root.used 6930 1608582030
disk_usage.root.avail 214260 1608582030
disk_usage.root.used_percentage 4 1608582030
disk_usage.root.boot.efi.used 1 1608582030
disk_usage.root.boot.efi.avail 120 1608582030
disk_usage.root.boot.efi.used_percentage 1 1608582030
Now would like to show only those, whose name contains “_percentage”.
I tried to use this:
/(_percentage)/
but this does not work.
However, if I do the negative lookup like
^((?!percentage).)*$
it shows all values - but not the ones, having “percentage” in it.
My question: How can I only show those values having “percentage” in it?
