Filter and display only "message" field
Could you please advise if it’s possible to filter only “message” field from elasticsearch datasource?
I’ve set “Metric” to “Logs” (as I need to display text data) and query like:
(message: “~Disconnected." OR message: "~Net error~”), but the query output contains all elasticseach fields:
while I would like to display only message field, i.e.: “06.01.2020 13:34:05.340; QUIK disconnected”
Thanks in advance!
