Hi
I posted this in the docs channel in Slack a couple weeks ago as the contributing documentation requested, but have not had a response yet.
I see that some of the docs use “-” to separate words in their file name, e.g. dashboard-create.md, and some use “_”, e.g. dashboard_folders.md and dashboard_history.md. This leads to files not linking to the documentation, e.g. _index.md is expecting “-” for the two files leading to the links not working. I don’t see anything in the guidelines about a file name convention. At a quick glance “-” seems to be more common, but there are many that use “_”.
- Should there be a file name convention for docs?
- Should images in the docs also have a file name convention?
- For the issue in the _index.md, should the files names be updated with any references or should I submit a pull request for _index.md to be update?
Thank you.
