Hello, Team, please clarify if Metrics:Logs → Object: → “lookup feature” is supported in Grafana Cloud compared to MaaS. This is how it worked in MaaS: you place the cursor on the field of a log type table in Grafana panel, and this text field somehow automatically (?) is represented with all minor details in a separate pop-up “Object” window. It was very useful in MaaS. Is it still available in Grafana Cloud? If yes - how to enable it? Research didn’t help so far. Thanks.
