Feature request to have OR operation between Adhoc filters
Feature request to have OR operation between Adhoc filters.
Currently when we select different adhoc filters, they are queried using AND operation. It would be really helpful to have option to choose between AND & OR operation for different adhoc filters.
–Rahul
If you find this feature really helpful I would suggest you to create a feature request issue.
If you want to implement this yourself you can modify the Grafana code. In combination with the feature request issue you’ve created you could create a pull request with your code changes. If lots of people upvotes the issue with a thumbs up emoji we’ll consider implementing/merging it.
Thanks
Marcus
Thanks, will file feature request.
