The screenshots show that the first alert comes, then after 5 minutes a message about its resolution comes, after 10 minutes the cycle repeats and so on for an hour.
In the alert setting, an interval of 1 hour is set. Alert resolution cannot come after 5 minutes, nor can a re-alert after 15 minutes. As you can see in the screenshots, the threshold is exceeded 1 time, then there are no errors, but there are alerts.
This behavior is repeated many times on different alerts. The number of errors in all alerts is the same as in the first alert. The screenshots show the alert settings. The condition for triggering an alert can be seen in the screenshot.
Alerts are set to email notification. Grafana version is v9.0.0. Promtail source - logs via Loki-Logs that are pulled from a common JSON file with logs. This behavior appears randomly, the rest of the time alerts do not give false positives. Please help me to deal with this problem.
