[root@grafanavbox ~]# sudo systemctl status influxdb
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/usr/lib/systemd/system/influxdb.service; enabled; vendor preset: disabled)
Active: failed (Result: start-limit) since Fri 2017-12-08 11:09:42 +08; 5s ago
Process: 4232 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
Main PID: 4232 (code=exited, status=1/FAILURE)
Dec 08 11:09:42 grafanavbox systemd[1]: influxdb.service: main process exited, code=exited, status=1/FAILURE
Dec 08 11:09:42 grafanavbox systemd[1]: Unit influxdb.service entered failed state.
Dec 08 11:09:42 grafanavbox systemd[1]: influxdb.service failed.
Dec 08 11:09:42 grafanavbox systemd[1]: influxdb.service holdoff time over, scheduling restart.
Dec 08 11:09:42 grafanavbox systemd[1]: start request repeated too quickly for influxdb.service
Dec 08 11:09:42 grafanavbox systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
Hint: Some lines were ellipsized, use -l to show in full.
