Failed to start grafana-server service
I can’t start the grafana-server service using the ‘systemctl status grafana-server’ command.
In /var/logs/grafana/grafana.log I receive the following message:
t = 2020-05-27T02: 08: 04 + 0000 lvl = eror msg = “Server shutdown” logger = server reason = "listen tcp: address http://grafana.mydomain.com:3000: too many colons in address"
Help will be appreciated.
Thanks in advance!
Did you explicitly set your domain name?
If so, maybe you don’t need the http:// part.
