Reading one file in grafana with promtail config file, It works fine for some time but after hour or so it gives the below error and I have to restart the instance again to rid of this error.
ERROR = “Facetting failed for {filename=”/var/log/tempdata2.log"}" permission set for this file:
-rwxr-xr-x 1 ubuntu ubuntu 21375 Apr 9 13:07 tempdata2.log*
Hi All,
the same here: Facetting failed for {filename="/home/radek/slurm/array_171-5.log"}
It worked ~1hr after the job has been executed. After that I am unable to read logs and getting the error like above.
Any help most appreciated.
In my case, updating Fluentbit to 1.7.9 version (I’m collecting Windows Logs with Fluetbit and sending them to Loki) and restart the Fluentbit service solve the problem.
[SERVICE]
Log_File C:\Program Files\Graylog\sidecar\logs\fluentbit.log
storage.path C:\Program Files\Graylog\sidecar\cache\fluentbit\data
[INPUT]
Name winlog
Channels Security,Windows PowerShell
Interval_Sec 1
DB winlog.sqlite
[OUTPUT]
name loki
match *
host lokiIP
port 3100
labels job=${sidecar.nodeName}
I’m using Loki deployed on Kubernetes, and I’m doing the central management of the configuration of Fluentbit config files and services with Graylog Sidecar, all installed on the same Windows Server from where I’m collecting the Windows Logs.
Let me know if you need any additional information.
Dear All,
It seemed that my issue was easy to fix by choosing the longer time period:
There is ‘last 1 hour’ set as default. Even though logs are available, they don’t appear. Try to change this to 7 days and then more logs should appear.
Have a nice week!
Cheers,
Radek
I met this issue as well and sovled the issue the same as you did. So I am wondering if that is owning to there is no log generated during the last 1 hour and we have to set the query period longer than that?
