Extract k6 stdout results to Editable Email Notification Content
Hi Team,
I want to automate the k6 test results and send them automatically after the test using the Post-build edit email option.
I tried to extract the results summary using ${BUILD_LOG_REGEX}, ${BUILD_LOG_EXCERPT}, and ${BUILD_LOG} none of them work for me.
Does anyone guide me on this?
Hi @Gerard
Are you using Jenkins and its email extension to send emails? A bit more context will help.
Cheers!
Yes. I’m using Jenkins and Editable email notification extensions. When I try the below options it prints only the lines containing the count.
${BUILD_LOG_REGEX, regex=ā€œ.?(count).?ā€}
Guide me how to capture the entire results summary or any other workaround
