9.2.3 -
I am trying to merge 2 queries and to fill in missing time points . -
When I use the Join By Field transformation to combine them I then use extract fields to parse the JSON object and it doesn’t return any data. -
What happened?
Inside the table view the variable being extracted doesnt create any new fields -
4 News fields to pop up when extracting my JSON object. -
I am having issues using a transformation -
Nope -
No
