latest
tag on TIG stack viadocker compose
Achieve a view where the daily resetting vaule is carried through all the way to 23:59:59 (or some other immediate time right before midnight). At about midnight, there should be a vertical line to go down from previous value to zero
Right now this is a basic Time Series chart of the data. -
What happened?
Right now, only new values are written to influxdb. These are daily measurements that reset at midnight. So a value that is set at 5PM, will not be written again if it has not changed until midnight when it is reset to
I don’t know if this is easily solvable with changing the query on the displaying side in grafana? Or if maybe there is a way to script rewriting the last value into influx right before midnight. It’s only for about 10 entities that I’d like this done.
