Hello team,
I need to get annotation for last past (24h, 48h, etc). Global time range should not influence that. I found AnnotationsSrv, which has getGlobalAnnotations method which might work, but time range is hardcoded there, so you can not change it with options object. https://github.com/grafana/grafana/blob/master/public/app/features/annotations/annotations_srv.ts#L91
Are there any ways how I can get global annotations for the specified range programmatically?
Thank you in advance
Alex
