Latest Grafana 8, postgres DB as data source.
Is there a way to populate the database with results from an expression?
I’m querying time series data, timestamp and value, from postgres. I’m using the expression feature in the panel to create new values, 200 day MA, etc.
I’m able to display the new values…awesome. But I would also like to put those new values back into the database.
Is this possible? If so where do I start?
Thank you.
