when I use the Explore mode with an InfluxDB data source, I can see either a graph or a table (by switching FORMAT AS), not both at the same time. Is this a bug, or does InfluxDB not support both graph and table data?
It says: “Explore will show the results as both a graph and a table enabling you to see trends in the data and more detail at the same time (if the datasource supports both graph and table data).” under https://grafana.com/docs/features/explore/ , thats why I’m asking.
Thanks!
